I've seen the upgrade for sale already somewhere - I think maybe I saw it in canada - at 3dshop.ca? I hear it's involved and requires drilling holes in your printer. It's also quite a bit of money. What country are you in ianmellor? Please put your country in your profile location setting.
CORRECTION 13 DAYS LATER - It's a pretty simple upgrade to perform because they have you replace the whole head as one piece and there is indeed no drilling. That was an incorrect rumor.
Labern 774
There will be an upgrade kit available this month ( first quarter 2016 )
It will contain all the parts required to convert your machine to a 2+.
Once installed you can change the machine to 2+ in cura and install the 2+ firmware.
