Dim3nsioneer 557
So what was the solution now?
foehnsturm 969
No real solution yet. So far:
Forget slicer created supports. Just make up a simple box shape and do a bolean subtract with the part. Use the remaining as support.
PVA doesn't stick to PLA. So, if you print PVA on top of a PLA surface make sure it isn't an island but instead connected to some PVA structure nearby. It will still curl up and need some millimeters height to recover.
I don't use stuff like priming towers. In this case there had to be to separate towers because of the poor adhesion I think.
Edited by Guest- 1
I have heard PVA doesn't wash off that easily as well. Have you experienced this?
I guess you wouldn't want PVA to melt into the PLA as it could dis-color it?? if this is the case then the adhesion between the two would be a difficult balance to allow it to stick but not melt into it.
foehnsturm 969
foehnsturm 969
hmm.. I thought PVA should have some bond with PLA.
Have you tried different types of PVA, could there be a difference?
Have you tried your PVA with ABS? Is there a difference?
- 4 weeks later...
foehnsturm 969
Dim3nsioneer 557
Can you please add a picture from below... that't the interesting side...
foehnsturm 969
Dim3nsioneer 557
Looks really nice... thank you. I guess you had no gap between PVA and PLA?
foehnsturm 969
I set the distance to 0.05mm
Dim3nsioneer 557
Was that the results of some tests or just an educated guess? I could imagine it looks better than if one would leave no gap.
Probably the hardest thing I ever printed was a propeller. This one came out very very nice!
PVA prints up to about 170C which is probably not hot enough to melt the PLA below it. Consider maybe covering the top and front of the machine such that the PLA is at it's glass temp? Not sure if that will help as then you need even more fan.
Maybe instead turn off the fan while printing PVA? And turn the fan back on when printing PLA?
foehnsturm 969
That's one of the feature requests I have for new Cura. The other one is a dedicated printing speed setting for support bottom layers (especially those on top of PLA). But I'm still collecting ...
- 1
foehnsturm 969
This looks promising for the first time, thanks @gr5 for bringing up the temperature aspect. Now printing Scaffold with 215°C instead of 195°C (E3D claims it's good for 190-220)
Fingers crossed ...
foehnsturm 969
... and still collecting feature requests:
I had to set support / horizontal expansion quite high (3mm) otherwise support would sometimes start with super tiny blobs on a slanted surface (which don't stick at all). Obviously now all support structures are inflated but the intention is to modify only the tiny ones.
foehnsturm 969
foehnsturm 969
foehnsturm 969
foehnsturm 969
In your photo with the support on top of the tube - it looks like it worked, right? Was it simply raising the temperature?
Are you using your crossflow fan still? Or is this tube a "zero fan" print?
Dim3nsioneer 557
Hmmm... maybe the adhesion between PLA and PVA can be influenced with the thickness of the first PVA layer? Please don't ask me how to do e.g. a thin first PVA layer on top of PLA with the current software but it might be interesting to see if this is a way physically anyway.
Maybe rising the ambient temperature helps? Are you currently printing with an open printer at room temperature? What about a heated chamber for that purpose?
Just ideas...
Edited by GuestLink to post
