Thanks!
So if I want to change the filament do I need to give "Head move Z (mm)" a value other than 0?
You don't need the "Head move z" (actually messing with it will make it harder to resume the print), you do want to enter a "x y parking coordinate" so the hot nozzle moves away from your printed part and doesn't burn a hole in it... 0,0 should be fine.
To figure out at what height to do the pause, you can use Curas layer view to find the first layer of the numbers, multiply this layer number with your layer height to get the height in mm.
To avoid a bit of stringing when it does the parking move, you might also want to enter in your normal retraction amount (you'll find it under the advanced tab)...
Just make sure to actually manually prime the hotend with your new black filament (press it all the way into the block until pure black filament comes out the nozzle), otherwise you can get problems with under extrusion as it starts the black layers, and they will initially be grey rather than black.
clinton 6
Thanks!
Edited by GuestLink to post
