Idea. New location for Z limit on UMO+
Posted · Idea. New location for Z limit on UMO+
I still need to make a short youmagine page as well with my very simple sensor holder and quick instructions...
@amedee - while you are at it... :)
What about the camera holder from your video? Is this a raspi-cam?
Are the model files available somewhere?
    Posted (edited) · Idea. New location for Z limit on UMO+
    Updated firmware with https://bultimaker.bulles.eu/experimental and its perfect!
    Thank you Amedee :)
    I'm using Neotko's homing at bottom of bed modification.
    Also tried the software bed levering, very cool :)
    AND finally I have a nice *beep* instead of that hideous stock beep !!11
    I did an PID autotune....and was wondering would it make sense to be able to build
    a firmware and you could set the PID values in the online builder ?
    Last week i got lots and lots of MAX TEMP errors on bed (UMO HB upgrade kit) and I ended up removing the whole crappy connector and solder the wires for the sensor and power for bed directly on the bed.
    But now the room temperature readings are different....if I turn on printer its shows 24° on hotend and 20° on bed....maybe if my soldering have altered the effect on the sensor...also I need to use hotter bed to get stuff to stick...will autotune PID fix this difference or is that another matter (temp difference) ?
    • 3 years later...
    I know I a getting an old post up again but I am trying tu fit this modification on my old Ultimaker original with a 32 bit board, custom heated bed and Marlin 2.0... I think some things have changed, I can't find the Prepare menu for example...
    Did somebody allready try this in marlin 2.0? (I am very bad at code... but I try to learn and understand)
    Thanks a lot!
