Don't buy CF filament. It's no stronger and no stiffer. The CF is cut up too small to make any difference. I've tested some of these. It sure looks sweet though!
Yes you will need a few steel nozzles and you will need a few per roll. Or get the hardened nozzles which last much longer.
Anyway don't get CF but consider getting the Olsson anyway as you can then change nozzles and that's great all by itself.
Which strength quality is a problem? If you want parts that aren't as brittle (can be dropped from very high) then you want it to simply be more flexible - not more strong. There are lots of great filaments for that. But if for example you are making a quadcopter arm then there isn't much (anything?) out there better than PLA.
If you want it strong enough that a human just can't break it or can be driven over with a car then you want nylon. But still will not be good choice for something that needs to be stiff - like a quadcopter arm.
1
krys 206
Hi howardsmith,
Well, you *can* use CF20 with your regular brass nozzle, but it will wear out much more quickly, or so I have read. I have not yet tried CF20 myself.
If you want the steel nozzle (hardened steel or stainless steel, apparently there is a difference), then the Olson block is the way to go.
Just getting the Olson kit is the cheaper option and would get the job done.
But the Extruder Upgrade kit includes a lot more and makes a big improvement over the UM2 (better feeder, better temperature control, faster heat up and more). So, if you can afford it, I suggest the upgrade kit.
Both the kit and the Olson block kit include the exact same hot end and nozzles, so they are fully compatible with each other, no difference.
I also read that E3D nozzles work to and really anything with a metric M6 thread.
As for where to get stuff in the UK, I do not know. You can get the Olson block and the Upgrade kit from Ultimaker itself, of course. 3DSolex is also a possible source on your side of the pond.
Additionally, 3DSolex now has a new upgraded Olson block replacement you might consider if you are not going to get the full upgrade kit.
Anyway, people with actual CF20 experience can probably provide better insights, but since I have recently done the upgrade kit and recently done a bunch of research, I thought I would try and help out.
Hope this help clear things up. Good luck!
