It's also possible if you group objects, ctrl click the object you want to put above the rest and translate it.
I'm not quite sure what this fixes?
You could also try not printing it as support, but an object sandwich of sorts (you put another circle in between and mark it as print with PVA nozzle)
That sounds like a very interesting solution to the following issue, but doesn't affect the adhesion?
nallath 1,124
