Since I just did the up gradation, am stuck on the calibration process. The printer wont let me move ahead to raise and lower the build platform. But, I checked the Z Limit Switch. Its is functioning properly.
Checked all wires. They see intact.
Thanks
-Small
stu_le_brew 40
that is really weird, as the Z switch is further down
worth trying the raise then lower the print bed to see if that does the same
also check that during the upgrade you have not trapped any wires, maybe somehow cut into a wire somewhere ?
Edited by GuestLink to post
