Modelled and printed a holder for my beloved UMO (will publish it later...)
Test pending...
Nevertheless, THANK YOU Robert!! Great writeup..
Edited by GuestModelled and printed a holder for my beloved UMO (will publish it later...)
Test pending...
Edited by GuestI can't find the zip file with the model?
QuoteHello Rob! I Hope you're doing well..yamahadxf.zip.zip
Let me dive straight to the main point... I am trying to open the output generated file from DXF2Gcode software in pronterface for vinyl cutting on my Creality Ender 3 V2 but I see no object on the build area whereas when I open the same file in online gcode viewer (NC Viewer // GCode Viewer and Machine Simulator) it shows weird paths going out of the build area and on the other hand the same file can be opened in another gcode viewer called as g-code simulator (g-code simulator (nraynaud.github.io) but the size of the object is larger than that of what I started with and is also out of the build area. IDK what's going on? I am playing with the parameters of the DXF2Gcode for like 2 weeks but no success. I loved the software for its simplicity but now it's in my head now.
I am also attaching few screenshots with this message and two zip files where one is dxf file that is to be imported in the dxf2gcode software and second zip contains the generated file from the same software.
Image-
1st image is of the dxf2gcode software.
2nd is of the dxf2gcode file which can not be opened in Pronterface.
3rd is of the same file which is opened in NC viewer where you can see the weird paths.
4th image is where you can see the object is seen but is out of the build area and overscaled. ( I have also tried to rescale the image to smaller and somehow managed to get the object in middle of the build plate but still no success to open it in pronterface). Please have a look at it and let me know what's wrong and do let me know if you want more details on this.
Note*Printer is not connected while I was taking screenshots but nevermind it's the same even though the printer is connected.
Edited by shivamkale27
Torgeir 244
Hi Robert,
What a great write up, thanks a lot..
Thanks.
Torgeir.
AreDigg 8
I used this write-up as inspiration to be able to use my Ultimaker as a plotter. But modified the output from dxf2gcode slightly so I could use it with the SD card. I did not use Inkscape or pronterface, but used online to convert svg to dxf.
It works great, however I have to look at how to make dxf2gcode optimize the plotting, as you can see from the video it does not follow the logical fastest path. Could be because it is meant for milling and cutting hardware.
It seem also to use the F-rate for Z-axis for retracted head movement as well, but I may just hardcode that in the g-code settings in the future.
I wish also there was a possibility for a grid or overlay in dxf2gcode, or at least a way to easily determine the output size directly.
