Thanks @SandervG! Glad to hear that they are in the works. If you can say, is it a matter of weeks or months?
Also if it is the better part of a year away, my employers might see it worth the risk of using a smaller nozzle on the AA core. Is there a conceivable way to make a smaller nozzle work on the AA core, or is there absolutely no chance of it working? We'd be prepared to purchase extra cores if necessary to determine the right configuration.
SandervG 1,405
Hi @Rossboss, it is true that these different nozzle sizes are compatible with the Ultimaker 2+, they are not for the Ultimaker 3.
The Ultimaker 3 has a very different designed printhead. If you have one, I am sure you have seen the print cores.
The print cores are there to make your user experience easier and more straight forward. Among other things, the Ultimaker 3 can read data from the print cores so it knows what nozzle is in there, and for what materials this is a good fit. Swapping nozzles would compromise this concept.
But we are working on different set of print cores to be added to the Ultimaker 3 parts. So you will be able to use them with a little bit of patience.
The full picture is a little bit more complex than 'just' designing a new nozzle. As part of the concept, it should also come with pre-tested and pre-configured profiles for each material, especially aimed for that print core. Hence that we did not have a full set ready at launch. But it is coming
Let me know if you have any further questions!
