fbrc8-erin 265
Are you using Cura 2.3.x or the Beta 2.4?
I'm finding the Beta 2.4 prints really nicely without a prime tower (by default). Beta 2.4 does some new things with controlling the temperature to reduce oozing and the need for a priming tower. Here's my latest-- sliced in Beta Cura 2.4, design by XYZWorkshop.
Not quite all the PVA is off in the photo.
Could you include some pictures of what's going on with your printer?
2
alandpoole 0
Correction,
I make the raft in PVA. I also fixed the initial adhesion problem by setting the prime tower flow to 150% and making an initial layer overlap of 0.2mm.
However, i still have the problem that because the PVA does not stick to the PLA, the primed PVA material gets dragged across the print and ruins it. Can anyone help?
My suggestion is that a firmware update could be made to have two prime towers, one for each nozzle/material.
Thanks in advance of some support.
