I don't think we support that now. You can change the angle of the infill a bit, but there is no "infill shift"
I updated the issue with some informations...
@ghostkeeper ? an opinion ?
@daid : "Infill is calculated with the front left corner as "center" point. (as that is actually 0,0) So the grid is rotated around that point."
http://ultimaker.com/en/community/6937-ability-to-shift-infill-pattern-in-cura#reply-55665
DidierKlein 729
Why not model the infill, based on the infill settings and use it as infill mesh?
So just model a triangle infill with the same settings (distances, width of walls). Add it to the plate, per model settings, infill mesh. Then just place it in the wanted position.
I have tried this with some custom infill and it works.
(@DidierKlein combien de passage de la buse pour un mur de seulement la largeur de la buse ?)
@smartavionics did !
https://github.com/Ultimaker/Cura/issues/2412#issuecomment-330134682
Next Beta ?
1
Next Beta ?
We'll see, it all depends on whether the PRs are acceptable to the Cura guardians or not. Even if they are basically in favour, changes always seem to be required. Chill.
2
This is of course not a priority but it is really an important function, and not just for me!
@smartavionics how can I try the "Infill Shift", I use CURA 2.7
You would have to compile CuraEngine from source. This is no trivial undertaking. The alternative is to wait for a beta that includes the feature.
I understand ... I'm patient.
This function looks awesome!
Are there any nightly builds so people without coding knowledge (like me) can test it?
Sorry, you will have to wait until a beta of the next release is produced. Hopefully, this new feature will be merged by then.
@nallath comment on github : "CURA-4338"
it looks like the Bible...
darkdvd 978
Maybe I missed Something...
@nallath ?
@SandervG ?
Somebody ?
