UM2+ SD card reader
si2w
Posted · UM2+ SD card reader
Hello,
It seems that I broke the SD card reader. It worked well since 2013. Now the printer crash when trying to read a SD card.
I tried :
- 4 different SD cards with various speeds => FAILED
- format them is FAT32 => FAILED
- flash again the last stable Tinkergnome firmware. Flashed successfully but didn't solved the issue
- flash again the last stable original UM2+ firmware. Flashed successfully but didn't solved the issue
The UM2+ is still working with the USB cable.
My conclusion is that the SD card reader is probably broken.
Someone knows which manufacturer / part number they use ? It's not mentioned in the BOM on github.
I don't know if there are more details in Altium. I cannot read the files...
Thanks
Best,
    Posted (edited) · UM2+ SD card reader
    Circuit maker can open altium files, but I use mac and it’s only for windows
    Could anyone take a look to help?
    Software free to open the files
    http://documentation.circuitmaker.com/display/CMAK/CircuitMaker+-+((FAQs))
    The altium files are on
    https://github.com/Ultimaker/Ultimaker2/tree/master/1249_Ulticontroller_Board_(x1)
