I have noticed that recently all the text in the Cura UI has increased in size by something like 50%. This is on a Linux screen:
Is this just the "cura-themed" parts of the interface, or also the system-themed parts such as the preferences?
Just the cura-themed parts, the preferences dialog appears to use the same size fonts as before.
It is probably due to this change then:
https://github.com/Ultimaker/Uranium/commit/6cc4363480386c126df32c576c89a17d9df7d9dd
Only 10 lines of the important settings are to be seen at once... that's where the endless scrolling starts... It's not unusable, but very inconvenient...
The original design that we got only had room for 4-5 settings at once. I changed the margins so we could have at least a reasonable amount of settings on screen.
Setting visibility pre-sets is something that is pretty high on the backlog.
Once Cura 3 has launched, I might return to where I started and make a compact theme.
I have started that here: https://github.com/Ultimaker/Cura/issues/2678
For now the gain is room for about 5 extra settings.
A dream would come true!
ahoeben 1,968
I agree. Unfortunately the design team has started focussing more and more on larger screens/window sizes. Once Cura 3 has launched, I might return to where I started and make a compact theme. This should be fairly easy to install/apply to your Cura installation.
burtoogle 515
dimensions: 1920x1080 pixels (508x285 millimeters)
resolution: 96x96 dots per inch
For me, the text really doesn't need to be as big so it would be great to have a preference to scale the fonts.
