kmanstudios 1,120
If I am not mistaken, 90° is perpendicular to the plate, and 0° is parallel. That would be why 45° gives you more support and 65° less.
When I tested my printer with all the test files for overhangs and angles, I found for my printer, 65° was about the point of the clean underside. While it could handle up to 85°, it would get really messy underneath. Not a problem in hidden areas though. This would not be the same as a bridging situation though. I have found it bridges pretty nicely as long as the gap is not too bad.
1
rebekah_harper 60
Hiya,
if I understand correctly that there angle of the features above this height don't need support?
if you look in the support section there is an angle setting which should range from 0 to 90 deg. when making a change here you will find that the higher the value the more parallel to the plate the over hang becomes in order to generate support.
90 deg = parallel to build plate.
depending on the layer thickness I will set it around 45 deg.
for lower layer height I increase the value to about 75 ish as I need less support.
hope this helps
Bex
