Dim3nsioneer 557
Well the bottom layer is clearly not getting squished enough. The lines aren't even touching in the photo. That's usually the most important factor for how well the part sticks to the glass. So turn off auto leveling and simply rotate the 3 screws a little counter clockwise to move the bed up a bit. A half rotation should be enough.
In case the OP is a pro user and does not want to use a tinker method like the one suggested by @gr5, a good point of making sure the active levelling is working properly is to clean both nozzles and the glass before performing the active levelling.
gr5 2,210
When the printer is starting the bottom layer - look at how thick the lines are going down. You want them squished flat like a pancake - not ropy.
MFettinger 1
I went through all of these problems too and I've come to some conclusions based solely on my experience. PLA manufacturer and filament color matter, Hatchbox technical support actually said their filament is not compatible with the Ultimaker line. I've had the same brand of filament act differently, black was very viscous and sticky, printed wonderfully and stuck to the bed, then red wouldn't. I tried glue, no glue, tape, and weights on the brim all to get it to stick.
Different brands and colors leave behind variable amounts of residue after a print. So when I have a fail like your describing the first thing I do is remove the glass build plate and wash it with dawn. Try not to touch the glass with your fingers, reinstall the built plate and level it. Try your print again with a slower initial layer, I sometimes slow down to 20 or 30% speed until that first layer is on the glass then crank it back up to 100%. And Gr5 is right too the lines should be smushed together more. Hope this helps.
Edited by GuestLink to post
