double check you are adding it to the material profile that's being used.
I missed it and found that the one I was using was way lower in the list than the one I thought I was using.
Works for me (with both UM material and a custom material). Are you on Cura 3.0.x?
I am using Cura 3.0.4
Checked that and put it more numbers on different materials and still nothing.
But it shows for others...
could you send me screen shots of the material in use on your slicer and and the material profile you edited and I will see if I have the same issue.
@Redanto: Are you using an UM2?
For the UM2, you set the material on the printer. Cura does not know what material you will be printing with. As a result, it cannot calculate the price.
If you want to select the material in Cura, go into Machine Settings and change the gcode flavor to "Marlin" (instead of "Ultimaker 2"). This will give you material selection in Cura, and as an effect it will enable the calculation of price and weight.
sorry to say but you're incorrect. they are two completely separate things. as you can see you can get a price on any machine. it just need to know how much material it needs to create the part.
the slicer know how much filament it will be using so all it needs is the price/quantity purchased.
Sorry to say, but I implemented this functionality (https://github.com/Ultimaker/Cura/pulls?utf8=%E2%9C%93&q=is%3Aclosed%20is%3Apr%20author%3AfieldOfView%20cost). I am fairly sure I am correct.
You seem to be using a modified definition of the UM2; the standard UM2 does not have a "nozzle" dropdown.
interesting... good find - i'm just curious: can you explain which material profile is used for the calculation? And how did you choose a specific material? I don't see it in your screenshot?
@ahoeben - in Cura 3 there's a new machine action "UM2UpgradeSelection". You mark the Olsson block... et violà - there is the nozzle dropdown. Quite nice... but it's still not possible to select a material...
Giggle, you are quite right. I forgot I added that too ;-)
Change the printer flavour to reprap in printer machine settings
So i figured out that it was the custom printer that was not working so I adde a printer they already had and changed the the build settings to my print bed and it worked. I will try changing the "flavour" to reprap.
Changing the flavour to "reprap" worked as well.
Edited by GuestI went through most and it seems to work for them apart from UM2 flavour. go figure lol
Do you have a local and a network S5 in Cura? One could have been created by a project. Cura might confuse them and check the one which has not stored the cost information for. But it's just a speculation as it seems to work for me.
Dim3nsioneer 557
Edited by GuestLink to post
