fbrc8-erin 287
You could probably clear the message by turning off the printer--it should be gone when you power it back on.
For the button issue, I would try removing the front of the button and checking for debris inside the button, and making sure the hex nut is tight where it should be on the inside. If that doesn't do the trick, reach out to your reseller. Removing the button front is pretty straight forward and only takes a minute: https://ultimakernasupport.zendesk.com/hc/en-us/articles/115004187086-The-Button-Won-t-Click
fwp 0
I have the same problem...
