It's an issue, it can cause color pollution on dual prints. Not a big issue, but still something to fix. And someone has asked before pretty sure I mentioned it a long time ago in some beta test report....
2
robinmdh 100
short answer: It works and nobody has asked for it to be different, so why change it?
long answer:
"Then the bed rises and the head moves to a point half way back on the right hand side" is one of the probe locations.
And this is left over from when setting the bed level (after measuring or when starting a print using measured data or user calibrated data) could not be done at any height/location so it had to set the height that has been measured at one of the probe locations.
We've changed some things in how we store/calculate the hotend height so now I/we can change it fairly easily but it hasn't been an issue as far as I know for anyone, you unique butterfly, you ^ ^
But it was one of the things I still had on my not important should still do it sometime list in the back of my head... I'm working on Cura connect in the mean time and there are bigger things missing there![:D](//content.invisioncic.com/ultimake/emoticons/5a33abe7dfbbe_1f600copy.png)
So please let us know how big of an issue it is?
