Yes i know this. But i meant in one model.
kmanstudios 1,120
Split that model into parts.Yes i know this. But i meant in one model.
Use infill meshes. Take care: this is not very easy, but once you get it...
A short how-to:
Unselect "keep models apart" and "drop models to build plate" in Cura preferences
Import a second object (for example a simple cube)
Put Cura in "custom mode"
Select the cube, and use the button "per object settings" on the left side
Select "Infill Mesh" and enable that setting
The cube now turns transparent gray.
Position the cube to overlap part of your model. It should overlap with the section that you want to change the infill for.
Also with "per object settings" select the option "infill density"
Set it to the desired value. All is more or less illustrated in the screenshot below
The picture shows a cube on the buildplate with infill 20%. Locally, with a rotated 2nd cube, the infill % is raised to 100%.
What happens is that the volume where the cube intersects with your object is locally sliced with different infill.
2
kmanstudios 1,120
I had no idea that could be done. Thanks!
A short how-to:
Thanks a lot. I'll try this tomorrow
kmanstudios 1,120
I think you showed that before, but I mistook it for different parts having different wall and infill by being part of the model. I did not realize you had done what I now understand.
Thanks for showing this again.
kmanstudios 1,120
Thanks for the tutorial tomnagel!
I was just able to use this method to solve an issue I had been having with a certain print. I was able to create a hollow in the model to fill in during printing for weight and still keep the main model in strong, good pieces.
1
kmanstudios 1,120
In the current stable version of Cura, you can select a model and then go to 'per model settings' on the left side tool bar. It is the icon that looks like 3 hourglass type of shapes. There you can choose almost all settings to apply individually.
Edited by GuestLink to post
