Most of the time I make a gap between parts of 0.1mm for a tight fit (requiring force to insert), and 0.2mm for a normal or loose fit. This is usually sufficient for the normal irregularities due to layers, rounded edges, ringing effects, occasional small blobs, slowing down on corners, etc... For small gaps, I take larger tolerances, based on experience, or after trial and error. For example, a 4 mm hole usually ends up as a 3.5mm hole. Then the best solution is to go through it with a 4.0 mm drill (manually!!! Never electrically, this melts PLA). Rounding bottom edges with a 0.5mm round, reduces elephant feet.
Printing slow and cool improves tolerances. Printing hot and fast makes it worse, since the pressure can not change immediately in the nozzle upon stops, retractions, etc. So that causes more irregularities in the print.
kmanstudios 1,120
Tolerances can be a funny thing as it can also be material dependent and even brand dependent. But, I do agree that it would not be a Solidworks issue considering it is an engineering level design and manufacturing product and proven in many industries.
FFM/FDM is not the same as injection molding for repeated accuracy.
I am just now finishing a project that:
