yellowshark 153
@gr5 is right in everything he says but you may have misinterpreted. I do not have the latest Cura version and I think some of the wording has changed. First there is your nozzle size, then your line width and finally your wall width. In older Cura nozzle size was defined in printer settings and in addition within the main cura settings you had additionally line width and wall width. I think nozzle size and line width have now been combined, if you check the Help I suspect this will be confirmed.
You need to set line width to 0.8 and you are recommended to set wall width to 1.6, i.e. the wall will be made up of two passes.
Do not forget with a 0.8 nozzle you are extruding twice as much material as you would with a 0.4nozzle and therefor you will almost certainly need to adjust your normal settings - i.e. your print speed (slower) or your extruder temp (higher) or a combination. But I think @gr5 recommendation is wise.
Your overall finish is poor so you need to improve your settings; I have always found a 0.8print to be good, indeed often better although the geometry will decide for you whether it is the best choice.
If I can work out how to post a pic on the new forum I will post an example for you to aim for.
gr5 1,870
Is this spiralize mode? aka cup/vase mode? Just curious. I assume not as if so it changes everything about my answer...
Well I recommend a shell width of 1.6mm and a line width of 0.8 so double check that. Two passes allows for a better quality outer shell. Also I believe there is still a bug in the default AA 0.8 profile where it enables "retract on layer change". Make sure that is off as that could explain everything you see here.
But really the most likely issue is speed - try slowing it down to 50% speed and if that fixes these "pin pricks" then slowly increase the speed (do all this in the TUNE menu while printing) until they come back so you know your top bump-free speed.
Outpost31d 0
Thanks for that, the default line thickness (that is 'shell width'?) for 0.8 is 1.37 so i'll change that to 1.6. 'Retract on layer change' is off by default and I will try the tune menu. Appreciate your help!
