kmanstudios 1,120
You can do what @Dim3nsioneer suggests as it will work on all versions of Cura. I am playing with the new 3.2 beta (Which, other than a few oddities, is quite stable in my experience) and created the file here for you to look at if you install the 3.2 beta. It is using a new way of modifying the infill and is very flexible. No counting layers and very intuitive in that you should be able to follow what I did. Just select the top and bottom boxes, go to per model settings and choose the "Mesh Type/Modify infill setting of other models" and then choose the infill for that object. It will modify the infill where it overlaps the other models. I just made the bottom box to fit the bottom (A guess of where you would want it) and then cloned the box and moved it up.
I do have automatically drop model to buildplate disabled to facilitate such operations.
UM3E_5a71f47768eb5_UM3_Dogbone-32Beta.curaproject.3mf
Does the job nicely
edit: Does require 3.2 beta to function.
Edited by kmanstudiosclarification of program version to use. and...typelexia....
Dim3nsioneer 557
You can increase the top and bottom thickness and set infill to zero. That should do the job if I got you right.
