12 hours ago, gr5 said:Usually you fix this by lowering the temperature which makes the pla more viscous so it leaks less. And also slowing it down so the pressure in the nozzle is lower so it leaks less. I recommend playing with these 2 parameters in the TUNE menu until it stops stringing or until it strings much less.
Actually the print on the right with the least stringing looks the worst - something wrong with the Z I think where it didn't move the right distance and it then over extruded some of the layers - what kind of printer is this? I think it has a problem with the Z axis sticking.
Actually the less retraction I set, the best part quality I get but with lot of stringing.
From left to right:
LEFT: Retraction: 30mm/s 3mm 210ºC
MIDDLE PART: Retraction: 35mm/s 6mm 205ºC
RIGHT: Retraction: 50mm/s 8mm 210ºC
When I added too much retraction stringing was almost eliminated but I got poor quality (like under-extrusion).
I can try to lower temperature to 200º and print slower, thanks for the advice.
Going back to one of the initial question, how can I set in Cura to avoid starting each layer in the same area and enter/exit the part in the same positions?
Thanks again
gr5 2,210
