Yes, this happens to me when I create things with Fusion 360. I could rotate them by those 90 degrees before they become a STL. (Or I could look into changing this in Fusion.) It is just strange that this 90 degrees turn seems to be needed for my parts 90% of the time. Since it does not matter, I should probably just 'rotate my thinking' when I start the object in Fusion. I was just wondering if there is a place for cura commands to be run during import.
Thanks for getting back to me about this.
SandervG 1,521
I think it has to do with how you export your model, and the point of origin is at the wrong/not where you mean it place. This point decides what is up and what is down in your model. How to change this 0,0,0 position may depend on what software you use. Do you design the models yourself, where this happens?
