Then I'm stumped as well...
15 hours ago, pdrinkut said:Have you tried contacting official Ultimaker support yet?
No, do you think they are able to help? You mean the Admins of this forum?
The Tolerance Test from Makers Muse was really bad. I was only able to unlock the 0.5mm and 0.4mm wheel using force to crack it.
I think my first layer is to sticky, the bottom of the print was molten togetter completely.
For the first layer I now reduced the temp from 205 to 200, raised the speed from 20 to 30 and set the fan to 50%.
Maybe it is only the first layer holding everything together.... I hope...
Edited by Dragon2781No I mean actual tech support from Ultimaker or the reseller that you bought the printer from:
- 4 weeks later...
On 2/22/2018 at 7:44 AM, Dragon2781 said:No, do you think they are able to help? You mean the Admins of this forum?
Did you ever manage to resolve this? I have the same issue with my Tolerance Test from Makers Muse, I could not even unlock the 0.5 one.
27
14
7
4
Popular Days
Feb 17
18
Feb 16
16
Feb 19
10
Feb 20
4
Dragon2781 27 posts
kmanstudios 14 posts
pdrinkut 7 posts
Brulti 4 posts
Popular Days
Feb 17 2018
Feb 16 2018
Feb 19 2018
Feb 20 2018
Popular Posts
kmanstudios
I just got up and having a caffeine boost. So, maybe can answer in a bit. But here are some pics with very tiny details. I am using, in this case, ColorFabb Shining Silver and Matterhackers clear. Som
gr5
Okay so I just looked at your bench photos. In the hull there are two slits - those look like underextrusion - either the Z moved too far for those layers or a filament tangle or... not sure what.
Brulti
A suggestion: if it isn't a settings problem, then maybe it is a hardware problem? @Dragon2781 Do you have another AA printcore you can swap to make your tests again? Maybe the printcore h
Posted Images
Dragon2781 0
Thank you for all the hopes and wishes but I have the same issue with the other AA Core.
I want to print a tolerance test and see if this works.
