Hi - First time Heat Flood..UM-S5, it can still happen. Just wnt to make sure its still a Heat gun?
- 3 weeks later...
Just had a massive clog last weekend. 15 hours of PLA and PVA build up. Not sure what caused the issue but the door opened and the print head got stuck in the empty space between the bed and the right side panel.
Took me couple of hours to clear the clog. Used a heat gun on an electronics repair station to melt the plastic and tear away larger chunks. As the OP mentioned, getting the cores removed from the print head bottom plate was quite difficult. In the end, I blasted hot air directly onto the bottom plate while holding it with adjustable pliers. Then pulled the cores out when the plastic started to give.
Not sure ´yet if the print head or the cores still work. At least the core lifting switch is broken. But other than some nicks and scratches on the print head plastics, it looks like we got off lightly.
As a side note, I find it rather perplexing that the UMS5 does not have crash detection. I do believe the TMCs they use, do have this implemented on the hardware. Considering that a Prusa, that's quite a lot cheaper, has a really good crash detection system!
The reason should be very simple: The print object or parts of it have lost their adhesion to the heating bed and have been carried away. This causes the nozzle to stick to the printing part, but the stepper continues to convey material because it does not notice anything. The material can no longer come down through the nozzle, but the pressure increases continuously. It burns its way up along the hot nozzle - and quickly pours in your printhead.
Digibike
- 1
I feel your pain, we had the same thing happen to us about three days after getting our machine (S3) last year. Made a huge mess, bent sheet metal pieces and everything, even blew open the front plastic cover. Ultimaker wound up sending us a whole new print head with two new nozzles in it. At the time they said they never saw anything like it.
- 2 weeks later...
you both Win, I only lost, my Olson-Ruby extruder. Yes, loss of adhesion with Nylon Carbon Fiber was my problem.
Top Posters In This Topic
12
8
8
6
Popular Days
Mar 6
12
Mar 6
9
Mar 8
8
Mar 7
7
kmanstudios 12 posts
SandervG 8 posts
brightorange 8 posts
gr5 6 posts
Popular Days
Mar 6 2018
Mar 6 2019
Mar 8 2018
Mar 7 2018
Popular Posts
gr5
This really sucks, man. to fix it you need a heat gun. Hopefully it's PLA as if it's a high temp material you are even more screwed. This has happened to many people and they get through it eventua
SandervG
Hi @brightorange, thank you for your reply. What is misleading about kman's response? You speak of a clog, and even though you can now consider your printhead as clogged the origin of this probl
gr5
It's not enough to watch the first layer. You have to check that it squished hard. These are photos of 0.3mm thick first layers and how they look with the head starting off at different heights - no
Posted Images
Digibike 107
The fact that you have the problem with the liability always under control, honors you, but also shows that it happened to you, at least in the beginning, too. I also usually have no liability problems, but in the last case, I had a tiny carelessness in the process for the 2nd Printing part, which gave me this surprise - see also the photo of the previous poster. and that at a printer of 4400 euro and 2 Core's for a total of 240 euros. The last time that something happened to me, by the way, was 2014th So prints not synonymous since yesterday ... Can you imagine what I think about it, when I see that the printer for 4400 euros so produces a damage, in principle would be preventable for 0.30 cents ...? The liability error was clearly my mistake, only the impact would be so easily caught in a failed print with primitive means, instead the printer is allowed to produce damage to these capitals.
That's not to say the least, to say the least, no matter how well you get along with the printer. Something simpler can be prevented, especially since the magnets and the temperature control are already implants ... Then it is not necessarily so consuming a filament monitoring as the S5 - it is automatically collected the disturbance as soon as the fan can no longer cool the core - then anyway no control of the Core's happen!
Greetings, Digibike
