kmanstudios 1,120
Vasemode woould have left only a single shell. That seems to have thickness. It is weird. It would help to know printer, filament, settings etc. otherwise it was the work of the printergeists at work.
I think maybe not enough cooling. Fan is working? Have the other successful prints had a larger X-Y area, thereby allowing more cooling prior to subsequent layers? Maybe try a combination of slower print time, increasing minimum layer time, and maybe enable Lift Head? I sometimes print 2 or more small area parts to provide more cooling time and pick the best one when its done.
1 hour ago, nomadic318 said:I'm not sure what filament I'm using
ummmm, same filament that was successful so far? The reason I am asking is if you went from a low temp filament to a high temp filament, that would create massive underextrusion.
The version you show is a previous version that is before my time. Sorry, but there are those who are familiar with it.
Yes, when i bought the printer a year or two ago I bought a few spools of the same fillament. Thats all I've ever used.
6 minutes ago, nomadic318 said:Yes, when i bought the printer a year or two ago I bought a few spools of the same fillament. Thats all I've ever used.
Just ruling out things....have you tried the hot and cold pulls and see if there is a clog?
Please show the other settings as well. And can you zoom in on the part more? It looks maybe underextruded but I can't tell. and check your part in layer view - does it look fine there?
I can't tell from the photo but the only thing that makes sense to me is underextrusion.
Also when you post your settings, tell us what your nozzle diameter is.
jofleck 0
Is it possible that you accidentally switched on the vase mode?
