kmanstudios 1,120
7 minutes ago, SandervG said:Given some prints are fine, I reckon they got loose from the bed.
I would agree with this as I have printed tall, thin parts and then parts come loose, even just enough to wobble, it will still deposit the material as if it was still in that spot and eventually, you get a mass of cosmic plastic.
Edited by kmanstudiossevere typelexia
SandervG 1,522
Hi @Tibi, welcome to the community!
Do you also have a photo from the other side? Did the prints already get loose from the build plate or did somewhere halfway the print broke?
Given some prints are fine, I reckon they got loose from the bed. In that case, I would indeed recommend to level the bed, and clean the glass plate. Do you use any adhesives like glue?
At what speed is your first layer?
You might find some tips to help you in this post
