SandervG: I've just started a three day print involving lots of Breakaway, so I will have lots to report back on after that. It's of a bird, perching on a book lectern, looking down. 15 cm high. It will be using nearly 30 cm of Breakaway.
I don't have the photos you want, but it seems to leave flat surfaces spotless. Where I did have a few issues was with an irregular egg-style design which I printed on an end. Breakaway supported the print absolutely solidly, but when I came to break the support away, I was left with strands of Breakaway around the bottom of the print which, though not massively important,were quite tricky to clear. Towards the end, I was having to use tweezers to pull away individual strands.
For some jobs, I've been able to clear Breakaway just by using my hands, fingers and occasionally finger nails. After that, I've pliers supplemented by tweezers.
If photos will help, I'll post some once I've finished the three-day print.
1
SandervG 1,521
Hi, it looks like you have a good understanding of when to use PVA and when to use the BreakAway material.
I don't think there are any noticeable drawbacks in having it sit around, no more than regular PLA or your other build materials.
Can you show some of the surface quality you got when removing your Break away material? Did you use a regular plier to pull it off?
