Like what kind of fabrics? To wear?
You want to make sure that first layer is really in there, merge with the fabric. That is the most important. Because the fabric can move along with the plastic / print head you want a thick first layer and on the slow side of things.
- 2
fbrc8-erin 283
I think you need a fairly non-stretchy fabric. I think tulle or denim have been used. And then you'd probably want to use some binder clips to secure it to . the glass plate. Beyond that...I bought some fabric to try it out a couple weeks ago and haven't had time yet.
Ghene 24
Thank you! I was hoping to try printing on thicker fabrics. what sort of settings do I need?
