Is the part lifting off of the build plate? Is you build plate glass really flat? One of my UM3 glass build plates has a .007" (0.18mm) bow in the width (X axis) direction while it's perfectly flat in the front to back (Y axis). I turned it over so that the high point is in the center, rather than at the edges. If your nozzle is dragging on the part at the sides / edges, but not in the center, you might try turning the glass plate over?
Just a thought . . .
Brulti 176
Maybe a problem with the Z screw? Have you checked that there's nothing that could disrupt it's movement and that it is properly greased?
