filament.ca
econofill pla (16$ CDN / kg !)
extrusion multiplier into simplify, and débit (flow rate) in Cura (I see a problem, it is just for first layer in cura...)
nozzle clean, each time
material stuck in print core it's "breakable"
the fist picture: gcode made by cura at 120% of flow rate... (default print speed is 60mm/s or 3600mm/min)
the two others: made by simplify 3d... at 100% extrusion multiplier and 120%... with filament diameter to 2.72mm (print speed 80 mm/s)
Thanks for all
Yves
kmanstudios 1,117
There are things here that I am not sure of....
1. What brand? That can have a huge influence on quality and requirements.
2. Print speeds of 100% to 120%....that percentage3 is of what? Print speeds are measured in mm/s
3. Have you cleaned out your nozzles because at those temperatures you listed may have baked the plastic a bit. I suggest a thorough cleaning with hot pulls and cold/atomic pulls.
4. What material is stuck in Print core 2?
This would be a great start to diagnosing the issues.
