44 minutes ago, Kai_Re said:Octoprint or Atlasprint are no option as well, as we need a Windows based solution.
windows supports web browsers.
Do you mean that raspberry pi's are an illegal device to be in your company maybe? But that seems unlikely since cell phones, paper printers, 3d printers and many other's run on non-windows.
I'm guessing you misunderstood. You guy a raspberry pi. It's about 25 euros. You install octoprint on it. Now you can print using a web page. But maybe that's not what you want.
gr5 2,194
I'm not sure what you are asking but I have 3 answers for you:
1) If you are doing a showcase printer you could print the same thing over and over and push the part off with the head. I have done this with bracelets where one gcode file has been cut/pasted such that it prints one bracelet every 7 minutes for about 3 hours. Also the file is named auto.g (or something similar - I forget the name you need to do) and if you power cycle the machine it starts printing again without any intervention. This is a feature on the um2 series printers.
2) I think what you want is printrun. With a usb cable you can print from the command line. Also printrun comes with pronterface which is a really great interface.
Get pronterface here. It's free:
http://koti.kapsi.fi/~kliment/printrun/
3) For about $25 or 25 euros you can buy a raspberry pi and put octoprint on it. Octoprint will control a UM2 through a USB cable and can connect to your network and it supplies a web page. You can do everything from the octoprint web page so you can print parts from a phone, ipad, pc, mac, whatever. You slice and upload the gcode files to octoprint (there's an upload button) and it will store quite a few gcode files if you want.
Kai_Re 0
Thanks for the answers. Indeed printrun looks like a matching solution, but unfortunately the link http://koti.kapsi.fi/~kliment/printrun/ is not active anymore (already found some information on Github or http://www.pronterface.com/ as well, but also there the same URL is used... ? ).
Octoprint or Atlasprint are no option as well, as we need a Windows based solution. We also had a look at repetier.com, but didn't find a command line option as well...
A bit more background information to explain what we are doing. Our main functionality is transferring and storing files anonymously. As part of a demo, we are transferring a .gcode file over several instances, which should be printed at the end (using a Win10 device). Therefore the print should start as soon as the .gcode file is stored in a pre-defined directory.
