Clicking sound on bondtech
bastienb
Posted · Clicking sound on bondtech
Hello !
I recently changed my PLA supplier (now PLA economy from Colorfabb) in 2.2kg spool and I started to hear clicking sound on both my UM2+.
I have bondtech feeders, tinkergnome and (normally) I set everything up correctly. I do not have underextrusion at all... I tried to loose the tensionning screw on the feeder and to increase the printing speed but I still have this (VERY ANNOYING) clicking sound. It occurs each 5 or 10 seconds.
Maybe I did not hear it before because of the size of the spool and the lack of resonance...
Do you have an idea ?
If you need any extra info and/or pics, do not hesitate ! I am note sure what could be of use here...
Thanks a lot ?
    • 2 weeks later...
    If you start to hear clicking sounds when putting a 2.2kg spools on the back instead of the standard 750-1000 gram, the last thing you should do is speed up the print, and loosen the tension, try the other way around.
    thanks @phantom
    the problem was the increased friction due to the increased weight of the spool
    the tension was building itself on the filament guide and every 5/10 seconds the tension was released and it "clicks"
    I strongly advise a separate spool holder for this size...
    Now the spool is on a spool holder with bearings and there is less friction than with a regular spool (but it's taking a lot of place XD)
    I took care of the angle from which the filament enters the feeder and it's printing like a charm now !
    Thanks @phantom ?
