No not dual. It would show in the gcode. The Nozzle temp changes are not so random. The temp is set to 212 in Cura and at layer 98 it bumps it up to 226. Then from there on it drops the temp 4 degrees every 100 layers. Could it be a bug? Only just noticed this recently as I've just started to do larger prints.
Thanks.
Edited by Degs
gr5 1,870
Is this a dual core print? It cools the idle core so it doesn't leak as much.
