Posted (edited) · How to change printing direction
Hello,
I would like to change my printing direction become one same direction. Currently, it's run zig zag, I know it's for optimizing but that doesn't matter for me.
as we can see from the gif, it's printing on zig zag, I want it print on the same direction, ex: top to bottom and not continue in the middle.
Is there any configuration I can try to change the direction, or I should change something from the source in CuraEngine?
I attached the project file.
Thank you in advance.
CFFFP_幾何1.3mf
Edited by rkusuma
    Posted · How to change printing direction
    I read your question 30 times.  I read the answer 5 times.  I think I understand.  In the picture above it goes top to bottom and then the very next second it goes bottom to top.
    You want always top to bottom.
    @smartavionics - is there a control for this?
    Why do you want this?  For a smoother top layer?  Have you tried the ironing features?  Turn on "enable ironing".  There are a lot of things to play with in ironing.  I have heard that a speed of 40 gives a smoother result than the default of 20.
    8 hours ago, Aage Rasmussen said:
    you can change the line direction for Top / Bottom and
    Infill. Ex. [0.90]
    I am sorry, I think my question is not clear enough. @smartavionics has been replied my question at Github page ( https://github.com/Ultimaker/Cura/issues/5034 )
    I also made my question more clear there. the reason why I need it can print on same direction because the metal wire feeder only goes on one direction.
    • 2 years later...
    To @Carbon or anyone else who may know. I do understand the steps explained to change direction yet no "options" or that of an explanation of what to type is included in cura ([wink wink nudge nudge]but needs to be) because I've tried other symbols or percents but don't understand what to enter to get the desired direction. Thanks
    Hope this helps.....
    Helpful, thanks, BTW where did you find that
    GhostKeeper's setting guide plug-in......
    https://github.com/Ghostkeeper/SettingsGuide/releases
