Have you considered using magnets? Makes for a very compact way of keeping it closed. But of course it depends on how secure the lid needs to be, you still need to be able to open it after all 🙂
1
In PET snap-fit lockings work well, if not flexed too much. But I would not use it for regular PLA: it gets too hard and brittle after a year, and then they tend to break. I have no experience with tough PLA.
Depending on how secure the locking has to be, a screw and nut might also work. If you design a cage with some retention for the nut, so it can not fall out. Like the cages in these pics (although they are for a totally different clamping system, not directly applicable to a lid, but maybe you could use the basic idea).
Smithy 1,114
Unfortunately, I cannot help with your question, but respect about how you designed it, separated into components, exactly how it should be - chapeau 🙂
