I think you simply don't understand how to use support blocker ....
You need to clic on Support blocker icon, here a gray cube will appear
You need to drag and scale the cube where you don't want support
DO NOT put the cube on the buildplate or on the support, just on the face where you don't want the support (like on your big tower support top )
burtoogle 505
There's a setting called something like "use towers" that makes stuff like that, if you have it enabled, try turning it off.
