No, you don't need to worry about that. I apply some glue with the glue stick to the glass and then distribute that with a wet tissue to get a very thin layer of glue. After the print is finished and the glass is cooled down, the part comes easily off. You can try both variations, just a layer of glue or with the wet tissue. Both works.
If you print with other materials like PETG then you should use the layer of glue to protect your glass, but with PLA it is not a problem.
The glue stick works in two directions, it gives you a better adhesion and additionally if a material (PETG) sticks too well to the glass, the glue layer protects against chipping the glass.
1
Smithy 1,135
When you have a heated bed, you don't need blue painters tape. Use a glue stick or nothing on the bed and it should work. If you want for whatever reason the blue painters tape, then try to apply a thin layer of glue there.
Rabin_Dhamala 0
If I don't use blue painters tape, doesn't it leave scratches and make the bed surface rough and uneven in the near future after continuous uses??
