For best quality of the text, I would print it on its back, thus the text facing up. But I would design custom supports, so that I would use far less material, and waste less time. Similar to this test with support bridges shown below, after an idea of user smartavionics if I remember well. I don't know if this feature is already integrated in newer versions of Cura? (I am using an older one.) If yes, try that first: it will probably give a much better undersurface. I have UM2 (non-plus) single nozzle printers, so I can print in one material only (this is PLA).
gr5 1,877
stick with pla, yes. Much easier than other filaments.
You could print it on it's back (last pic) except for those "stoppers".
I'd probably print it in the first photo orientation. The front handle will be fine. 45 degree angles are fine and then you have bridging which prints reasonably okay. Although I'd fix the stoppers by adding a 45 degree angle at the bottom of them.
Also I would have the text only stick out by 0.5mm and it should be okay.
I try to avoid support and I don't think you need any support for either of those 2 orientations if you fix the stoppers in cad and shrink the text to 0.5mm extrusion.
ahp 0
Thanks for the advise!
