I agree with geert_2 - printing slower will help these a lot. There is something in cura that creates these but I don't quite understand how to fix them other then simply printing much slower.
Regarding the filament sticking to the nozzle - that should be improved if you buy ICE coated nozzles from 3dsolex (disclaimer - I sell ICE coated nozzles also). 3dsolex has these for S5/UM3/UM2 and more. Pretty much all their nozzles are ICE coated now. The coating is a mix of chemicals including some kind of teflon such that molten PLA (and I assume CPE/PET/nGen) doesn't stick to the nozzle.
geert_2 558
The PET I used (which I think is a sort of polyester, just like CPE?) has a tendency to accumulate on the nozzle while printing, and then this accumulation discolors into a thick light brown goo, which eventually sags and gets deposited on the print as big brown blobs.
Also, while traveling through space, the nozzle has a tendency to leak, and then upon arriving on the next wall, a blob is deposited on the side. Especially when printing fast, due to the nozzle-pressure not reducing immediately.
In my UM2, printing slow reduces the effect, but does not eliminate it.
I don't know if this is the cause of your phenomena, there could be other reasons, but maybe you could keep watching while printing a test piece? If it would be the above problems, you can easily see it happening.
