I'm not an expert on thin walls but maybe try setting Minimum Wall Flow to 50. And if that doesn't help @smartavionics understands this much better than me.
That does fix the behavior in the layer preview! I'lle make a test print somewhere this week, but suspect it will be fine. Thank you!
It seems to work from 15% up. Does that mean that the second pass was being printed at lower than 15% flow? In practice, the printer seemed to be pushing through the filament through at the same rate in both directions.
gr5 2,071
Verne64 0
That does
