But....
Doesn't Ultimaker use colorfabb for their filament? I don't really know. But the reels that the filament comes on looks similar.
I apologize for not being clearer. I was using Ultimachine filament, not Ultimaker filament. I don't know if Ultimaker gets their filament from colorfabb or not, but the colorfabb sure printed nicely:
Here is the print profile I used:
[profile]
layer_height = 0.1
wall_thickness = 1.2
retraction_enable = True
solid_layer_thickness = 1.2
fill_density = 10
nozzle_size = 0.4
print_speed = 25
print_temperature = 185
print_temperature2 = 0
print_temperature3 = 0
print_temperature4 = 0
print_bed_temperature = 0
support = None
platform_adhesion = Brim
support_dual_extrusion = Both
filament_diameter = 2.84
filament_diameter2 = 0
filament_diameter3 = 0
filament_diameter4 = 0
filament_flow = 100.0
retraction_speed = 40.0
retraction_amount = 4.5
retraction_dual_amount = 16.5
retraction_min_travel = e
retraction_combing = True
retraction_minimal_extrusion = 0.25
bottom_thickness = 0.3
object_sink = 0
overlap_dual = 0.2
travel_speed = 150.0
bottom_layer_speed = 20
infill_speed = 0.0
cool_min_layer_time = 5
fan_enabled = True
skirt_line_count = 5
skirt_gap = 3
skirt_minimal_length = 150.0
fan_layer = 1
fan_speed = 100
fan_speed_max = 100
cool_min_feedrate = 0
cool_head_lift = True
solid_top = True
solid_bottom = True
fill_overlap = 15
support_fill_rate = 20
support_xy_distance = 0.7
support_z_distance = 0.15
brim_line_count = 10
raft_margin = 5
raft_line_spacing = 1.0
raft_base_thickness = 0.3
raft_base_linewidth = 0.7
raft_interface_thickness = 0.2
raft_interface_linewidth = 0.2
fix_horrible_union_all_type_a = False
fix_horrible_union_all_type_b = False
fix_horrible_use_open_bits = False
fix_horrible_extensive_stitching = False
plugin_config = (lp1
object_center_x = -1
object_center_y = -1
gr5 2,192
But....
