I sometimes have kinda the same problem. only with PVA though (BB core) and only on slot 2 (right side)
At the first 2-3 layers it only prints air. well I am actually not sure it prints air, but suspects it's only moving the print head around. when putting a finger on the fillement next to the feder you can normally feel that it's pulling the filament (even if the head is clogged, it still have a small pull) when I have this problem I can't feel any movement on the filament.
Enabling prime blob results in the head moving to the corner as normal but then right away it moves away again. no extrusion.
I can start the same print 2-3 times with the same behavior.
So when I get this problem I "change" the fillemet. unload and load the same filament again, and the problem is gone. I know its not a fix. But it gets the print started.
Dim3nsioneer 559
Looks to me like the filament in extruder 2 is not at the right position (due to whatever reason) and it prints thin air first.
Enabling the prime blob for extruder 2 might give enough feed to fix the issue. If it is a hickup in the firmware, a Cura Connect reset might help.
