Yes I know.
But then I can't see the camera image that is larger in Cura than in Octoprint.
But thanks for the help 🙂
CURA Ultimaker Cura 4.4 released with new Intent profiles
As far as profiles and all that jazz go, my mb-master builds are going to behave the same as the UM builds because I don't fiddle with that part of Cura. When you say extremely slow are you referring to the speed of Cura itself or the speed of the print? Can you provide a project file that illustrates the problem?
2 hours ago, burtoogle said:As far as profiles and all that jazz go, my mb-master builds are going to behave the same as the UM builds because I don't fiddle with that part of Cura. When you say extremely slow are you referring to the speed of Cura itself or the speed of the print? Can you provide a project file that illustrates the problem?
speed of the print you can see in the 3rd image with Cura 4.1, I can print that project in 3h 17m in Cura 4.4.1 it estimate to print the same project in 16h 37m, I already tested the estimation in Cura 4.2 and it was extremely slow printing, it looks like it was only made for Marlin, in case of Cura 4.1 it perfectly works with Marlin and Klipper
Hello @ramsesiden, that's understood. Could you please attach the gcode for that print sliced by Cura 4.1 and 4.4.1 so I can compare them and see what's causing the big slowdown. Thanks.
Hello @burtoogle it is not only for that print you can test with any print using Cura 4.1 vs Cura 4.4.1 , Octoprint and Klipper using a Klipper profile, I can send you both profiles for Klipper if you need, you can test it with any print and you will see the big difference
Edited by ramsesidenI don't have Cura 4.1 installed so please provide the gcode for comparison. Any print that shows the slowdown will do.
On 11/19/2019 at 10:55 AM, midacl said:Just finished installing 4.4, and it crashes on startup. I've submitted the crash reports.
Windows 10 1809
Intel i7 5820k
16gb ram
Quadro K2200
I found that I need to run Cura 4.4 with As Administrator checked in the properties to keep it from crashing.
On 12/25/2019 at 3:11 AM, burtoogle said:I don't have Cura 4.1 installed so please provide the gcode for comparison. Any print that shows the slowdown will do.
Sorry for the delay, it was xmas and I was with my family merry xmas to all of you, here are the gcode files and images, in case of cura-mb-master and Cura 4.4.1 I'm using nozzle switch in 50 instead of 60 as it was in the orginal custom Klipper configuration Im using, other settings are the same.
TT_T800_Cura-mb-master latest version.gcode TT_T800_Cura4.1.gcode TT_T800_Cura4.4.1.gcode
Hello @ramsesiden, I notice that the gcode header in the 4.4.1 file contains this line:
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
Marlin expects the values to be in mm/s but most of the other printer firmwares (I believe) expect the values to be in mm/min.
I don't know how Klipper behaves in this respect but if it's like the majority of firmwares, it will end up using a very low speed limit.
As for the print time estimates, I cannot explain the big difference other than perhaps the print time estimate algorithm used in Cura got reworked between the 4.1 and 4.4 releases. That's possible.
1
I posted this in the Ultimaker 3D Printers section, but the issue seems to have started when I installed Cura v4.4.0, so I'm posting a copy here as well.
I am using 4.4.1 and there seems to be a big in the brim on outside only feature. Even with it enabled the brim is being printed on the inside and outside of my model.
Same problem here: just upgraded to 4.4.1 from 4.3.0 on prompting from Cura, to find it crashes at every startup, even when run as administrator. "Upgrade" removed old version - I said "yes" to remove all config files, so effectively a clean install.
Win10 Home x64 18362.535 Version 1903. Core i7 4790 + 16GB
Anycubic I3 Mega but not cabled.
one crash report submitted, have now fully uninstalled and reverted to 4.3, so no longer have any logs. Could recreate I guess.
Let me know if you want any other information.
Another one here where it crashes but it does it on 4.3 too. Doesnt seem I can run any modern versions.
Log file:
2020-01-03 11:57:08,011 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [394]: Loaded plugin FileLogger
2020-01-03 11:57:08,118 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [394]: Loaded plugin FirmwareUpdateChecker
2020-01-03 11:57:08,166 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [394]: Loaded plugin FirmwareUpdater
2020-01-03 11:57:08,197 - INFO - [MainThread] UM.PluginRegistry.loadPlugin [394]: Loaded plugin
2020-01-03 12:02:55,901 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [56]: Loading shader file [C:\Program Files\Ultimaker Cura 4.3\resources\shaders\striped.shader]...
2020-01-03 12:02:55,916 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [56]: Loading shader file [C:\Program Files\Ultimaker Cura 4.3\resources\shaders\platform.shader]...
Windows 10 64 bit 1809
Intel Core i3-3220
8Gb RAM
- 2 weeks later...
Looks as though I am a bit behind the curve on this since I am only an occasional user. But I offer my expereince for what it is worth. I am running using Windows 10 Pro. I uninstalled Cura 3.6 (I think it was) the installed 4.4.1. I found that the program hung up when starting and 'Loading preferences'. I started again and uninstalled 4.4.1. I then looked for and deleted all Cura 3.6 and 4.4 files I could find on the PC other than the downloaded installation file. On re-installation the program ran successfully immediately as the .run after installation' box was ticked and I loaded a file. I created a shortcut on the desktop and tried to run again but it failed when 'Loading preferences'. I repeated the whole exercise and had the same problem again. Unfortunately I do not have the means to revert to V4.3 as some people seem to have done. Is it possible to make this available for download again, please.
45 minutes ago, PaulTreble said:Looks as though I am a bit behind the curve on this since I am only an occasional user. But I offer my expereince for what it is worth. I am running using Windows 10 Pro. I uninstalled Cura 3.6 (I think it was) the installed 4.4.1. I found that the program hung up when starting and 'Loading preferences'. I started again and uninstalled 4.4.1. I then looked for and deleted all Cura 3.6 and 4.4 files I could find on the PC other than the downloaded installation file. On re-installation the program ran successfully immediately as the .run after installation' box was ticked and I loaded a file. I created a shortcut on the desktop and tried to run again but it failed when 'Loading preferences'. I repeated the whole exercise and had the same problem again. Unfortunately I do not have the means to revert to V4.3 as some people seem to have done. Is it possible to make this available for download again, please.
Older versions can be found on github here https://github.com/Ultimaker/Cura/tags
Note that we're not going to support anything other than the latest version (currently 4.4.1)
The 'hanging' you described is a known issue and on the backlog
I have just installed the latest Cura 4.4.1 application and have a question regarding the new “Intent” Profiles. Are they only available/compatible with users of Ultimaker 3D Printers?
The reason I am asking is because they do not appear to show anywhere in the version that I have just installed. I have a Prusa i3 Mk2 printer and use it for making sample parts for
model engineering projects, which I design in Fusion 360. If they are included in this installation would you please explain how/where to access them?
Kindest Regards,
DivingDuck 59
4 minutes ago, Danthelad said:I have just installed the latest Cura 4.4.1 application and have a question regarding the new “Intent” Profiles. Are they only available/compatible with users of Ultimaker 3D Printers?
Kindest Regards,
Correct. It's stated in the blog here:
https://ultimaker.com/learn/intent-profiles-ultimaker-cura-4-4
"Each Intent profile works with the Ultimaker S5 Pro Bundle, Ultimaker S5, and Ultimaker S3 when used with our range of PLA, Tough PLA and ABS materials – as well as compatible support materials like PVA and Breakaway."
Guess we should have included that in the release notes too.
When the right printer/material/print core combination is selected in Cura, the Intent profile will become available.
Thanks for that. You would think that they would inform you of this on the Download site.....
2 hours ago, Danthelad said:Thanks for that. You would think that they would inform you of this on the Download site.....
Yes it should have been made more prominent as this question has come up a few times. We'll try to put it somewhere, perhaps retroactively in the release notes.
It would be great to have universal Intent profiles that work on third-party machines as well, but the development effort for that would be astronomical.
We can always consider pull requests if people would like to make their own.
- SandervG unpinned this topic
Top Posters In This Topic
13
6
5
5
Popular Days
Nov 21
17
Nov 20
14
Nov 19
11
Dec 23
7
territerriterri 13 posts
maht 6 posts
nallath 5 posts
DivingDuck 5 posts
Popular Days
Nov 21 2019
Nov 20 2019
Nov 19 2019
Dec 23 2019
Popular Posts
thopiekar
Oh dear.. 😅 Yes, the plugins (all CAD ones) are incompatible now. I was recently very busy with something else (as Terri knows). So since the other thing was more important for the moment an
DivingDuck
I just installed the new release. First time I don't need to change/repair my setup files. 👍 Installation was w/o any problem. Windows10 Pro 1909, RX580 8GB.
midacl
Just finished installing 4.4, and it crashes on startup. I've submitted the crash reports. Windows 10 1809 Intel i7 5820k 16gb ram Quadro K2200
Posted Images
Pantard 0
FYI,
You don't need to do anything. Just save the gcode file to your desktop or where ever. go to the octoprint screen and upload the file. Simple. No complicated procedures.
