Thanks For thr reply.
I see more ghosting on your model that mine. So I guess this is what I would have to expect from a S5... I would expect better result from a $7,750 CAD 3D printer considering that I get better prints from the Prusa i3 Mk3 kit...
To get me wrong, I love my S5 but I think price/performance ratio is not competitive...
NBull 14
Hi Framar, what version of Cura are you using?
This is printed as 0.15 basic profile no changes to settings.
I have tried to mimic you picture angles.
Photos of 3d prints are a weird thing, somethings will not look as bad on photo and others will look worse then they are!
I dont think the print in your picture is that bad, I have seen much worse come from a s5.
I have a layer mismatch at the same spot on the hull as you. I think its more a combination of model angle and slicing settings, more then a layer shift. but yes its an inaccuracy.
The ghosting in my opinion is more likely do to speed, then the cooling fans. The s5 needs to print dead slow to not ghost.
The drooping in your windows are most likely do to to hige print tempter. it can also be because your fan is not working properly as you mentioned. so be sure that there are no filament stringing trapped in the fan's.
Here are som more Photos of my print. sorry for the photo quality but im not at the studio today.
