Invest in an octoprint setup. All the pause scripts magically work since you are bypassing the firmware interpretation of what to do. I would spend on a pi unless you have one just just get a cheap i5 box and drop Debian on it. That is in my immediate future as my pi3 are getting … tired.
7 hours ago, garypuppa said:I did look into OctoPrint. The Raspberry Pi I own is too old, so I will have to upgrade it to use OctoPrint. I may have to go down this path eventually.
OctoPi will run on a Raspberry Pi Zero 2 which is fairly inexpensive, or you might be able to get a 3B cheap given the age. Depending on what you have, you might be able to run it there, just don't use a webcam, since that's one of the most CPU intensive things it can do.
2 hours ago, jaysenodell said:I would spend on a pi unless you have one just just get a cheap i5 box and drop Debian on it. That is in my immediate future as my pi3 are getting … tired.
Hint: look at places that sell refurbished ex-fleet PCs. Hardware might be a couple of years old but they're cheap as chips. In my case I'd just buy a new RPi because of the power consumption (or lack thereof, specifically).
Amazon. Belink. 16G/500G with a 3.5 Alder. $us170. Power consumption 2x of a pi 5. That thing will run windows and slice STL. Octo is nothing. Last time I priced a modern pi it was $20 less.
im a huge fan of used hardware but for something like this it’s hard to beat those cheap cubes on amazon.
Here’s one for $130
Beelink New 11th Gen Intel 4-Cores N5095, Mini PC 8GB DDR4 RAM 256GB SSD, Mini Computer Dual HDMI 4K UHD/Gigabit Ethernet/Dual WiFi/BT
2 hours ago, jaysenodell said:Here’s one for $130
@jaysenodell Please don't try and sell specific products unless someone asks for a link to a specific product.
Also, that thing is not worth the price. It only has an Atom CPU - by far the lowest performance in Intel's range, way below even the lowest notebook processors, designed for ultra low voltage applications, but with how inefficient the x86_64 architecture is an ARM CPU running slower will run laps around it.
It probably doesn't come with an OS installed which means either buying Windows (bad idea - 8GB of RAM is a criminally low amount of RAM to run Windows these days) or manually setting up a free OS and then OctoPrint on top of that. whereas with a Raspbery Pi all you need to do is run the Raspberry Pi Imager software to flash a memory card with OctoPi and you're done.
So you'd be paying more money for something which uses more power than an RPi, you can technically use as a proper computer if you want to bother setting up a monitor, keyboard and mouse, but you won't want to use as a proper computer because the performance is so terrible.
You'd have a much better, cheaper and easier experience with a Raspberry Pi for a single purpose device like this.
Shouldn’t have been a link. Sorry if there was. The other info was to provide the context for the system.
I think we will disagree on the total cost of the pi systems. Power supply, case, and board for a 5 are actually more than that unit. If we are running octo then an atom is fine. My experience is that it will outperform pi arm if you use a similarly stripped OS install. That thing ships with windows but that’s crippleware on that low end device.
Pi have a place, but the price of the current systems … nope. The limitations of the affordable class… not worth it unless your development specifies embedded systems. If the 5 can get back to less than 1/4 of the cost of that system above ready to plugin and go then it will be back into the prime spot again.
For the record, I like the pi for embedded hardware development. Unless you need the GPIO I think there are more practical/affordable/capable options today.
So now you got me curious. I see rasp pi 4 B from adafruit for $35 and a case and power supply for $16 on amazon. beelink I see for $170. I know prices vary considerably around the world. Also I think octoprint came out before the raspi 4 and before I think the 3 so if the 4's are expensive maybe you can get an older model for less? I wouldn't know.
The 4 module with ports is $us65 and out is stock because the current model is the 5. The 5 is $us80. The power supplies on the $us15 systems are undersized. Current minimum for 4&5 is 5a. I had to run 5a on my 3s to support octo and that was without any overclocking. Cooling is always the problem. Fans draw a lot of power.
Beelink has a $us130 unit that outperforms pi all day. Just no gpio. Won’t be much of a desktop but for a print server/file store … hard to beat.
I think we're detracting a bit from the subject... although for what it's worth, I can buy a Pi 4B (and yes, it is in stock) for AU$62 with a power adapter for AU$16.45, an SD card which is plenty big for AU$12, and the Raspberry Pi foundation have official models to print your own case so I don't think we need to figure that into the equation 🙂 for a total of about US$59. It's also going to use less power in operation so you're saving some money there and it's silent (unless you install a fan, but I haven't needed to). I think you can actually run OctoPi on an RPi Zero 2 W which is a little under half the price of a 4B bringing the total down to about US$39.
Your mini PC might run rings around a RPi in performance and functionality but the Pi is more than capable of running OctoPrint (I'm doing it on a 3B+!) and that's all we're looking for here.
Same. Regular overheat with cooling. Not an issue. Will eventually add controllers (esp32) for enclosure via gpio. And will land on a 5 when I do that. I’m just not convinced the pi is right for normal people from a cost or complexity perspective.
4 hours ago, jaysenodell said:Same. Regular overheat with cooling. Not an issue. Will eventually add controllers (esp32) for enclosure via gpio. And will land on a 5 when I do that. I’m just not convinced the pi is right for normal people from a cost or complexity perspective.
Then let's agree to disagree and shut up about it 🙂
Top Posters In This Topic
27
11
7
6
Popular Days
Feb 1
8
Mar 23
5
Mar 22
5
Feb 28
5
GregValiant 27 posts
Garythebloke 11 posts
jaysenodell 7 posts
Slashee_the_Cow 6 posts
Popular Days
Feb 1 2022
Mar 23 2024
Mar 22 2024
Feb 28 2021
Popular Posts
dchansen
I am still playing tag with Creality tech support but in the meantime I have stumbled upon a workaround. If I select BQ(M25) instead of Marlin(M0) it pauses as expected. Once you have changed your fil
Botcan
Please try my solution which I have been using without any problem: "M0" command works! But needs a period parameter (in seconds) for my Ender3 Pro after changing my motherboard to a silent one.
jaysenodell
As a e3s1p owner, octoprint is the right answer. Just stop using the sd for anything that is more than fire and forget. While I like my e3s1p, I won't buy another one. I'll just buy somet
Posted Images
garypuppa 0
"I'm spending to much time working around creality's customizations". I 100% agree. I have spent WAY too much time trying to figure out work arounds to the 'Pause At Height' and 'Filament Change' scripts which I need for my prints. And don't get me started on Ender's auto-leveling!!!
