You cannot open a UM3 profile in Cura configured for a S5. The two machines are not compatible. You will need to open the profile file in Windows Notepad to see the jerk settings you asked about.
Voilá....All will be revealed. I put a .txt behind your file and it opened.
OK. In Windows All you do is RMB and choose "open with" and choose Notepad. Can't help you with anything Apple.
Opened your file in SolidWorks 2020 and it does have a problem. The left post does not touch the build plate so it leaves overhang that can't be printed. Starts stringing almost immediately. Also the engraving on the left side probably printed OK in PLA, but not so well in PETG because of poor bridging in PETG.
I buried the part .5mm into the build plate with a.25 layer height and so far it is printing pretty well.
What are you using on the build plate for adhesion? I use PVA slurry for PETG.
I use a glue stick.
Good news,
I used some of your settings and my prints turned out much better.
Do yo have any idea if the bottom and top patterns being concentric makes a difference?
Glad your having better success.
Quote "Do you have any idea if the bottom and top patterns being concentric makes a difference? "
I think it does. Fewer retractions. I also thing it leaves a more aesthetically pleasing appearance. You might try concentric infill at 100% as well. Again, fewer retractions.
That said, I've never experience a part so difficult to print in PETG. I tried altering my settings and I'm still not pleased with the result. Too much stringing.
This is a shield frame I have been printing for a couple of weeks. Only takes 45 minutes. Donating them to our family doctor who's specialty is Infectious Disease. Also our family dentist. The clear shield itself is 10mil, 8.5" X 11 letter size, clear PVC punched with a standard 6 hole punch. Very easy to make. I've produced 30 of them so far.
Edited by XYZDesignPro
For some reason using some of your settings I don't see any stringiness. I am printing at a layer thickness of .3. I found a sign maker with a laser cutter. Each face plate is between $1-2 depending on the material. The acrylic is the more expensive. I tried thick .17mm PVC, but the laser generated chlorine gas, and did not cut well.
Edited by gisleyLooks as though you have worked out an acceptable solution for PET. Glad I was able to help. Did the increase layer height to .3 help to reduce the stringing?
The minimalist" design I an printing is the Verkstan design:
https://3dprint.nih.gov/discover/3dpx-013306
The clear shields are just 10mil PVC binding covers I purchase from Lamination Depot located just north of you in Orange County.
LaminationDepot.com https://www.laminationdepot.com/binding-supplies-and-equipment/binding-covers/clear-covers
Approximately $35/100 pieces delivered. So the price is right.
Either way let's keep doing what we can to assist those health providers on the front lines . . .👌
No, I think the jerk setting and slower infill speeds helped. The clear covering material I bought at Staple's for twice the price is what did not laser cut well.
- 4 weeks later...
- SandervG unpinned this topic
Top Posters In This Topic
24
14
9
5
Popular Days
Mar 20
28
Apr 18
16
Mar 21
7
Mar 23
7
SandervG 24 posts
gisley 14 posts
XYZDesignPro 9 posts
christech4primary 5 posts
Popular Days
Mar 20 2020
Apr 18 2020
Mar 21 2020
Mar 23 2020
Popular Posts
christech4primary
Hey Sander....I'm printing lots of 'Ear Savers'...they help to prevent care workers ears getting sore from wearing face masks for a long time...not life saving but gives a little comfort! I've attache
SandervG
Hi all, First of all, I hope everyone is safe and sound! These are bizarre times, and a lot of people need help. At Ultimaker we also took notice and we formalised a plan that we feel all
mastory
I filled out the form, but see nothing added to the map. Is this because I am an individual, or a glitch in the form automation? I have 2 Ultimakers that can be available. One is dedicat
Posted Images
gisley 1
Can you give me the Clift Notes on the major settings?
