A look at the models you're trying to print would help. However, threads on an 8mm rod would be pretty damn tiny (depending on pitch of course) and not very structurally solid. You could probably print them fairly well by setting the layer height very small but it's really pushing it.
A gear wheel at 10mm diameter would mean the gear teeth are sub mm in size. The nozzle on the UM2 is 0.4mm so that is the absolute minimum size a single line of plastic can be (you may get it down to like 0.3mm but that's more for cosmetic things IMHO). So if my assumptions are correct those details are simply too small to be printed well. And they certainly wouldn't hold up to any kind of abuse.
Daid 301
I've done quite a bit of tinkering and tweaking on this area with my UM-Original. The UM2 gets about the same precision.
https://www.youmagine.com/designs/cat-gears-key-chain
These are the smallest gears that I think are possible. Printed with 0.4mm shell thickness. The problem lays with the 0.4mm nozzle that needs to put down 0.4mm lines.
http://www.thingiverse.com/thing:24253
These are the smallest threads I managed to make. Printed in this direction. Printing them sidewards is impossible at anything but "huge" scale.
On settings:
For gears you most likely want to lower the shell thickness to 0.4, you might need to tweak the infill-overlap and lower it (in expert) so prevent over-extrusion. And temperature, for small things you want to slow down the printing speed and lower the temperature. You could go as low as 190C. Also, turning off the heated bed and printing on tape is what I would recommend for anything small and not flat (but there will be people who disagree with me on this)
