5 hours ago, gisley said:I am getting my S5 Friday. How many frames can you get on a build plate. I read somewhere where they mentioned stackable printing, or do I have that wrong?
Hi @gisley, congrats on getting the S5, you'll love it! About what you're asking, the S5 has a large build plate, so you can fit a lot of shields on it. I've made two types of arrangements. The first one has 3 shields on the plate, as shown below:
Using generic PLA on the Draft profile (0.2 mm layer thickness), with no Adhesion (i.e., just a skirt), it prints in 6 hours and 26 minutes (for 3 shields). That's 2 hours and 9 minutes per shield.
The other option is to use a x4 stacked version of the shield, available at Prusa Research. Using the stacked version, I was able to fit 12 shields on the plate, as shown below:
This arrangement, again using generic PLA on the Draft profile (0.2 mm layer thickness), with no Adhesion (i.e., just a skirt), prints in 1 day, 3 hours and 5 minutes (for 12 shields). That's 2 hours and 16 minutes per shield.
I'm using the 3-shield option for several reasons, the main one being that there is no need to separate the masks from each other, and also there's no need to print vertical supports for the little hooks that hold the visor, which sometimes detach from the bed and can ruin the print if left unattended. Also, the 12-shield option requires almost exactly 500 g of filament, meaning that, on a 750 g spool, the second print will pause half way, which defies the benefit of 24-hour non-stop printing. Overall, the 3-shield option is a cleaner arrangement in my opinion, and, as you can see, it's even slightly faster than the 12-shield option. The only disadvantage of the 3-shield option is that it requires your attention every 6.5 hours, to remove the print and start another. I've arranged my timing so that I start a print just before going to bed, and wake up when it has just finished printing.
Print times can be reduced further, by selecting a layer thickness of 0.25 mm. This will reduce the print times of both arrangements by 15%, at the expense of print quality. I've stayed with 0.2 mm, but you can experiment with 0.25 mm and see if the result is acceptable for you. It very much depends on the quality of the filament too. I'm using the cheapest filament I could find, so I don't want to risk pushing it too much. Experiment, and see what works best for you.
5 hours ago, gisley said:Also what are you using for the clear plastic part? Thanks.
I'm using a laser-cut transparent visor, which a local company makes for around 1 € per piece, at the exact specifications as published by Prusa Research. I get the visors and rubber bands from this local company, and manually assemble everything. This is the final product:
I hope this information helps you and others out there. Feel free to ask anything about the printing process, etc. I'm happy to help in any way I can.
gisley 1
